Date/Time: Sat, 15 Mar 2025 03:52:10 +0000
Weekend bars not showing.
View Count: 415
[2022-07-09 14:34:35] |
User509979 - Posts: 1 |
Hi, Not all weekend bars are showing in my intraday / tick charts. See screenshot below, which was taken today (Saturday 9th Jul at 3.30pm UK time.) The left-hand panel is an intraday chart, and you can see only 3 bars loaded for Sat 9th July. I have tried reload and recalculate options but I am only able to view partial data for the Saturday, rather than all data. I do have the 'Load All Weekend Data' option enabled in Chart Settings > Advanced Settings. https://www.sierrachart.com/image.php?Image=1657376804948.png |
[2022-07-12 08:21:17] |
Sierra_Chart Engineering - Posts: 18789 |
We see what the problem is. This will be resolved in about an hour. At that time: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
