Date/Time: Sat, 15 Mar 2025 23:50:00 +0000
Study - Spreadsheet Formula
View Count: 577
[2022-07-09 03:45:18] |
nicktrader - Posts: 744 |
To see the POC volume of each bar, I use the Study "Spreadsheet Formula" and refer to the Study "VPOC for Bars" with this formula "=VAP(ID3.SG1,0)". I have greatly reduced the number of bars to calculate <100. I noticed now that this study causes the chartbook to load twice after opening. Is there another way to see the POC volume without loading a second time? Many thanks |
[2022-07-09 08:47:10] |
We do not see a saved chart which is part of a Chartbook reload twice upon opening when using this study: Volume Point of Control for Bars There must be some other reason for this. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.3 - Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-09 09:57:53] |
Thank you for the quick reply. But the source of the problem is the study "Spreadsheet Formula". Please see pic. I have opened a new chartbook with only one M3 chart and there are only two studies in use. I use "Spreadsheet Study" to be able to see the values in the Chart Value window. |
[2022-07-09 21:25:12] |
We see the problem. This will be resolved in the next release.
