Date/Time: Fri, 14 Mar 2025 22:26:42 +0000
trial
View Count: 357
[2022-07-08 16:35:56] |
User706766 - Posts: 3 |
Hello, I have activated trial version. it is possible to use Footprint and Dom? I have charged different chartbook but doesn't function.
[2022-07-08 17:09:13] |
John - SC Support - Posts: 38678 |
While on a trial, all the system capabilities are available, including Numbers Bars and the Trading DOM. If you received a chartbook from someone else and you are not getting any data for the charts, then open the chartbook and select Edit >> Translate Symbols to Current Service to change the symbols from what is in the charts to what your symbols need to be. That should take care of it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
