Date/Time: Fri, 14 Mar 2025 22:26:43 +0000
30 second opening range
View Count: 839
[2022-07-08 13:14:08] |
User148596 - Posts: 217 |
Hi, I'm using a study price overlay from a 1 second chart to get the opening range of the first 30 seconds after the market opens. Is there a way to get this to draw an extending rectangle automatically or do I need to just use the stair step draw setting in the high low for time period setting and just use those lines to draw an extending rectangle? Thanks |
[2022-07-08 14:33:47] |
John - SC Support - Posts: 38678 |
It gets a bit tricky to convert the information into something you can use, but it can be done using the Study/Price Overlay and the Spreadsheet Study. Use the Study/Price Overlay to get the data into the chart you want. Refer to the information for this study here: Study/Price Overlay Study Then use the Spreadsheet Study on that same chart and enter the following into cell K3 and L3: =MOSTRECENTNONZEROVALUE(ID1.SG1@3:ID1.SG1@1000) =MOSTRECENTNONZEROVALUE(ID1.SG2@3:ID1.SG2@1000) Where ID1 is the ID of the Study/Price Overlay study. The second range value will depend on how many rows you have setup in your spreadsheet. This will give you the lines extending from the beginning of the time period for the High and Low to the end of the chart. If you want the area filled in to look like a rectangle, then use the Top/Bottom Fill Draw Style to fill it in. Refer to the following: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
