Date/Time: Fri, 14 Mar 2025 22:31:38 +0000
nymex
View Count: 413
[2022-07-08 11:59:47] |
User530136 - Posts: 2 |
My Nymex crude chart does not update. When logging in, historical populates but it does not update from then on. My other exchanges operate fine. Please advise Thank you. |
[2022-07-08 13:34:53] |
You need to update Sierra Chart to the current version: Software Download: Fast Update The issue has to do with delayed data support in older versions. There are some changes with symbol settings requiring an up-to-date version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
