Date/Time: Sat, 15 Mar 2025 16:07:47 +0000
The numbers on DOM are not aligned with respect to the columns
View Count: 885
[2022-07-08 10:12:44]
User749066 - Posts: 15
the numbers in DOM are overlapping with the rectangle boxes some are a bit above the box and some on on the box
refer the image u can see the right side number 50 is a bit above the box.
so how to align the numbers to be within the box like it is in DOM2 image
Date Time Of Last Edit: 2022-07-08 11:24:13
imageDOM.jpg / V - Attached On 2022-07-08 10:12:15 UTC - Size: 184.28 KB - 201 views
imageDOM2.png / V - Attached On 2022-07-08 11:24:10 UTC - Size: 59.15 KB - 160 views
[2022-07-08 13:58:57]
John - SC Support - Posts: 38678
It looks like the Tick Size for that instrument is .25, but you have the scale set to only show values at whole increments.
If you have changed the Tick Size because that is what you want, then you will want to combine the Market Depth data to be in the same increment. Refer to the following setting:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
[2022-07-08 14:13:39]
Also refer to:
The Chart DOM Scale
[2022-07-11 04:38:21]
i changed the tick size in chart settings of DOM to 0.5 and it's better now, but t added depth pulling and recent bid/ask volume to the columns but the values are not showing
in the DOM
refer the screenshot below
imageDOM2.jpg / V - Attached On 2022-07-11 04:38:12 UTC - Size: 577.44 KB - 143 views
[2022-07-11 15:08:55]
Is market depth data provided for that symbol? There may be a Symbol Settings change we need to make.
[2022-07-12 03:51:06]
i can see the numbers in columns when i change the tick size to 1 but i cannot see them when it is 0.5 ( same a symbol tick size)
i cannot see the market depth of limit orders in DOM
attached for reference
Date Time Of Last Edit: 2022-07-12 03:57:10
imagedom3.jpg / V - Attached On 2022-07-12 03:50:59 UTC - Size: 555.91 KB - 134 views
[2022-07-12 14:59:20]
You need to check with Global Data Feeds on whether they send Market Depth data for that symbol.
[2022-07-24 13:50:56]
i checked with them they don't provide level 2 data it seems
