Date/Time: Fri, 14 Mar 2025 22:26:42 +0000
Teton target attached order
View Count: 348
[2022-07-08 05:57:16] |
User900285 - Posts: 98 |
Hello, I did notice upon submitting a parent order with only an attached target limit (no stop), in the Trade > Trade Orders Window, the order status of the target order shows 'Pending Child-Client'. When I submit a complete bracket they show 'Pending Chilld-Server'. I am not sure if that is normal behavior. |
[2022-07-08 06:46:44] |
Yes this is normal. There is no support for a single attached order to be on the server before the parent order fills. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-08 06:47:17
