Date/Time: Fri, 14 Mar 2025 22:22:31 +0000
Unable to use Sierra after renewal
View Count: 352
[2022-07-08 01:42:37] |
Herloa2021 - Posts: 3 |
I still have problems with sierra, wont connect to live data, I use CQG for data through AMP, I read that I need to chane the service package to 10 Standard? I currently have and paid 3 Standard for 6months, I f I have to change SP, can you please change it? I tried to do it but it says that theres not available credit. Thanks for your help |
[2022-07-08 05:31:27] |
You can stay on Service package 3 for now for the next 60 days. We have put your service package to 3. When using CQG, market data has to come from our Denali Data Feed. So you need to complete the agreements, and activate the exchanges you need from here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
