Date/Time: Sat, 15 Mar 2025 07:55:59 +0000
Hide volume numbers from current traded volume columns
View Count: 622
[2022-07-07 23:07:38]
User123179 - Posts: 27
When I use this new feature every time I reload a chartbook or open each session the recent traded volume columns are blank, I have to go into global settings and turn on and off again each time to make them visible.
Is there a fix for this?
imageScreenshot 2022-07-08 090203.png / V - Attached On 2022-07-07 23:05:36 UTC - Size: 55.76 KB - 148 views
imageScreenshot 2022-07-08 090252.png / V - Attached On 2022-07-07 23:05:40 UTC - Size: 50.06 KB - 134 views
[2022-07-08 13:34:14]
John - SC Support - Posts: 38678
We are not understanding the particular workflow you are using to cause the issue. Please give us the steps you are taking to reproduce what you are seeing.
[2022-07-08 22:30:56]
Sure so anytime I open a chartbook, my DOM will now have blank columns where the recent traded volume should be (when hide volume numbers from current traded volume columns is set to YES).
If I go to global settings chart dom settings, turn hide volume numbers ... to NO , apply all
The columns come back.
SO each time I close a chartbook and reopen it happens again.
[2022-07-11 14:42:09]
Are you saying that when you set the option for Hide Volume Numbers from Current Traded Volume Columns to No that when close and open the chart again the setting is back to Yes?
If this is the case, then the main thing is to ensure that you are saving the chart. We are not able to reproduce this in any way unless we do not save the chart, in which case this is expected (the change is not saved).
[2022-07-18 21:11:34]
Sierra_Chart Engineering - Posts: 18789
Regarding post #3, update to the latest release of Sierra Chart:
We are not observing this problem in the latest release but we do not know why you would have it in any release. Update anyway.
Date Time Of Last Edit: 2022-07-19 09:50:51
