Date/Time: Fri, 14 Mar 2025 22:31:37 +0000
Opengl issue... dom pixelated
View Count: 594
[2022-07-07 19:59:39] |
User130077 - Posts: 10 |
Hi I have tried to find some help through the support board but can't seem to get anywhere. I am running a very good machine with 2 gpus so I can run 8 screens. I was hoping to use opengl to improve my ladders but as soon as I do so the ladders completely pixelategoing white. I have attached an image.i can send a better one if required. Is there anything I can do here at all? I would prefer not to buy another machine for my ladders if possible but currently its quite laggy. I run a second instance purely for the ladders as I believe this improves them. Best stuart |
[2022-07-07 20:45:51] |
John - SC Support - Posts: 38678 |
If you are using an AMD graphics card, then their implementation of OpenGL is not very good and there are known issues with it. This is most likely the reason you are having an issue. NVidia graphics are known to have a good implementation and we have not heard of any issues with those cards. The only solution (without changing hardware) is to not use OpenGL. Everything will run properly without it, but the graphics may be a bit slower. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-07 20:46:12
