Date/Time: Fri, 14 Mar 2025 22:26:42 +0000
CONNECTION
View Count: 350
[2022-07-07 17:03:06] |
User410776 - Posts: 6 |
hello, I havE a problem of connectin sierra chart. The error massage says: "Connect to data feed, service package does not support this function, or account is expired" Can you help please? Thank you. regards , |
[2022-07-07 17:18:07] |
This is resolved for your account.
