Date/Time: Fri, 14 Mar 2025 22:29:05 +0000
2 instances one scss file
View Count: 474
[2022-07-07 14:40:51]
nicktrader - Posts: 744
In both instances I use the same scss file that I manually "feed" with data one time per day.
After that I always copy the file from instance 1 to instance 2.
In "General Settings/Paths" there is the possibility to change the path. Can I change the path from instance 2 to 1 or will there be problems?
Many thanks
[2022-07-07 17:28:01]
John - SC Support - Posts: 38678
Do NOT make that change. There will be issues if you set the data folder for instances to be the same.
