Date/Time: Fri, 14 Mar 2025 22:22:30 +0000
Help connecting data
View Count: 385
[2022-07-07 12:30:07] |
Brandt Edwards - Posts: 2 |
Hello! I am new to Sierra and am having trouble connecting the data. I have attached the screen shot of what I am seeing. Is there someone that can help me with this? Brandt Edwardshttps://www.sierrachart.com/image.php?Image=1657196868138.png |
[2022-07-07 12:41:11] |
Do you have an Interactive Brokers account that you want to connect Sierra Chart to?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-07 12:41:18
[2022-07-07 14:13:25] |
I would like to use AMP as my broker. I have an account and have funded it.
[2022-07-07 16:52:49] |
AMP uses CQG, so you need to follow the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
