Date/Time: Fri, 14 Mar 2025 22:25:06 +0000
Add Search to Global Symbol Settings
View Count: 356
[2022-07-07 03:05:37]
User177741 - Posts: 48
It would be a great add-on to have a search/filter box on the top of the Global Symbol Settings window.
There are so many symbols it's hard to scroll through all of them!
Perhaps search by description as well as ticker symbol would be even better!
Kim
[2022-07-07 17:14:19]
John - SC Support - Posts: 38678
We have set this as a Feature Request.
In the meantime, with the symbol list having the pointer focus (i.e. you have clicked in the box) then you can start typing the name of the symbol and it will jump to the first available with the letters that you have entered. For example, if your symbol starts with ES, then you can type 'e' then 's' and it will take you to the first symbol that begins with E and then ES.
