Date/Time: Fri, 14 Mar 2025 22:22:31 +0000
Attached Orders - Targets quantity less than stop quantity -
View Count: 352
[2022-07-07 01:26:26] |
Steve Leon - Posts: 312 |
I read throughout the attached orders section but was not able to find the answer to my question. If you are trying to set up an attached order where you have a quantity of 3 contracts as a position and a stop with a quantity of 3 and you want to have two targets each with a quantity of 1 and your third position would be a "runner" (no target) that you could manage at your discretion - how would you suggest doing this. It seems like the quantity of stops has to equal the quantity of targets ? Could you clarify if this can be done and/or any other suggestions on how to try to achieve this scenario Thank you |
