Date/Time: Fri, 14 Mar 2025 22:25:08 +0000
Bug when displaying VWAP label of a composite VbP on a TPO chart
View Count: 413
[2022-07-06 21:49:23] |
dvant krypto - Posts: 43 |
Hello.... there seems to be a bug when trying to display the VWAP label on a VbP on a TPO chart. I have attached a screenshot. On the right you can see the VbP. The white circled area shows the label for the Value High in the desired location The VWAP label has the same settings (circled on Subgraphs) but does not put label in desired position (orange X), but rather shoved over to the right side values scale (circled orange) Side issue: Also, it seems that I can only put right-aligned composite VbP studies on a TPO chart. When I try to change the settings they just revert back to right-aligned after hitting apply. Are these bugs or is there something else I should be doing? |
Private File |
[2022-07-07 16:20:46] |
John - SC Support - Posts: 38678 |
It's not a bug, it is the way it is designed. Refer to the second paragraph at the following link: Volume By Price Study: Extension Line Labels Based on the above, you must have the POC for the other profiles set to display. -- It is correct that you can only put on a Right-Aligned profile that is separate from the TPOs. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
