Date/Time: Sat, 15 Mar 2025 06:14:22 +0000
filtering volume alert condition
View Count: 493
[2022-07-06 20:28:45] |
MarcOh - Posts: 171 |
Good evening, I need some food for thought please. I need a formula, a studie that will alarm when value X is reached in the TPO chart. How could this be implemented? Please see the attachment I would be very grateful for your help marcoh Date Time Of Last Edit: 2022-07-06 20:30:31
[2022-07-06 21:01:21] |
John - SC Support - Posts: 38678 |
You would need to use the Volume by Price Threshold Alert V2 to get your alert when a particular price level is over a certain value. You can not get to it from the Volume by Price or TPO studies. Refer to the following: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-06 21:28:55] |
right. But this study does not work in a tpo chart, right? No other opportunity, via the studie (VbP) itself?
[2022-07-06 21:59:22] |
You are correct, you would have to use the Volume by Price Threshold Alert V2 in a separate chart. There is not another option given the way the TPO chart works. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
