Date/Time: Fri, 14 Mar 2025 22:29:04 +0000
Order allocation not copying trades
View Count: 380
[2022-07-06 17:44:46] |
L2Ltrades - Posts: 61 |
I am using order allocation to trade 3-4 accounts with the same broker. When the position is closed, one or two accounts are always skipped and the close order is not executed. I have ended up in the red and having to ask the broker to cose the position. How do I fix this.
[2022-07-06 22:03:08] |
First thing we want you to do is to update to the latest version: Software Download: Fast Update And let us know if you still have the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
