Date/Time: Fri, 14 Mar 2025 22:31:37 +0000
NumBars Calc Values - Questions
View Count: 424
[2022-07-06 17:09:42]
User993067 - Posts: 174
Newbie to the Calculated Values Tools Grid...few questions
1. Calc Value2 resets to zero after every change in NBCV1 or NBCV2...correct?
So it does not hold data like NBCV1?
2. Can I change the periodicity on these tools ex...(ASK Vol-Bid Vol)
Can i change the delta to 10 bars?...like on VBP?
3. Can I import the value of an indicator not listed in drop down into the grid?
Say I want to follow adx or RSI but see it in the grid?..no graph
4. Can I import VBP data into the grid?
5. Can I import values from another chart (different periodicity) into the grid?
Say I execute on 4 bar reversal charts...but use 10 bar reversal as filter
6. Alerts when variables in grid meet criteria?
thx
[2022-07-06 18:43:11]
John - SC Support - Posts: 38678
1. It depends on the particular subgraph that you are displaying. This will be particularly true for the Pullback Column data.
2. The only way to change the periodicity is to change the period of the chart.
3. No, you can not display data for other studies in the Numbers Bars Calculated Values study. Refer to the information for the Study Summary Window, which might be what you are looking for, here:
4. No. See #3 above.
5. You can display the information for another chart in the Numbers Bars Calculated Values, but not at a different periodicity. It only works when the other chart is the exact same period and number of days. Refer to the information here:
Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart
6. Yes, you can use the values in alerts. But refer to the following as there are some special concerns that you may need to deal with:
Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas
[2022-07-06 19:17:24]
thanks for response...can i do similar in spreadsheet system/alert..study?
[2022-07-06 19:58:05]
Sorry, but we are not sure which questions you want answered relative to the Spreadsheet, as your original questions do not apply directly to the spreadsheet studies. Please let us know the specific questions and we will answer them.
