Date/Time: Fri, 14 Mar 2025 22:20:04 +0000
Teton: Got Order Reject Trade Order Error - LastTradingDateForSymbol
View Count: 491
[2022-07-06 14:09:19] |
YSS - Posts: 112 |
Hello, I tried to enter following order but got rejected, please advise thanks! Teton CME Order Routing (Order reject). Info: Trade Order Error - LastTradingDateForSymbol is not known. Need to resubmit order. Internal Order ID: 1058. Service Order ID: 41279. Symbol: M6BU22_FUT_CME. Account: XXXXXXXX | 2022-07-06 14:02:57.028 * |
[2022-07-06 14:35:04] |
Resubmit the order. You will be able to do it immediately.
[2022-07-06 14:50:53] |
YSS - Posts: 112 |
Ok thanks Any reason?
[2022-07-06 18:12:10] |
John - SC Support - Posts: 38678 |
Refer to the following: Sierra Chart Teton Futures Order Routing: Rejected Order (Last Trading Date Not Known) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-07 16:49:53] |
The information at this section has just been updated: Sierra Chart Teton Futures Order Routing: Rejected Order (Last Trading Date Not Known) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
