Date/Time: Fri, 14 Mar 2025 22:31:35 +0000
How to create a VWAP distance screener for stocks ?
View Count: 633
[2022-07-06 11:19:07] |
Alv P - Posts: 37 |
Hi, I need to create a screener for stocks that shows me the % distance from actual price to vwap How can I do it ? and how i can import all of them easily? |
[2022-07-06 17:06:42] |
John - SC Support - Posts: 38678 |
For the screener, you will want to use the Study Summary Window by selecting Chart >> Study Summary Window. This will show the various study's values from the charts. In order to get the price from VWAP, you first need to add the VWAP study, then use the Arithmetic Studies to get the final number you want. Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-07 02:47:35] |
Alv P - Posts: 37 |
Thank you John for your answer; I also can do it with study Subgraphs difference I think is the same ? But how I can load all the (TotalView) NASDAQ stocks ? There are hundreds, I can`t open this amount of charts one by one in a chartbook ..
[2022-07-07 17:11:52] |
You can use the Associated Watch List to scroll through the charts for the symbols you want. You can also import a list of symbols for the Associated Watch List. Refer to the following: Changing the Symbol of a Chart: Using the Associated Watch List For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
