Date/Time: Tue, 26 Nov 2024 11:34:03 +0000
Can login to board, cannot login to Sierra Chart
View Count: 1284
[2014-05-06 18:02:56]
organon1973 - Posts: 4
I can login to the support board, but not into Sierra Chart. I get error code 12007. I have made Sierra Chart an allowed application with my firewall, and am unsure how to proceed. Thank you.
[2014-05-06 18:17:23]
12007 = ERROR_INTERNET_NAME_NOT_RESOLVED
(The server name could not be resolved.)
Are you running any firewall software on your computer other than the Windows firewall?
Try restarting your computer.
Is Internet Explorer set to work off-line?
Refer to this section here:
https://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems
[2014-05-06 19:02:23]
User29972 - Posts: 9
No luck. Can you try logging in with my username and password?
Date Time Of Last Edit: 2014-05-06 19:07:48
[2014-05-06 19:09:21]
We have reset your password since it was posted on this public board. The new password has been sent to your email address.
We will have no trouble at all logging in using your Username and Password. This issue is specific to your system.
Are you running any firewall software other than the Windows firewall on your computer?
Can you try another computer.
[2014-05-06 19:56:45]
Can you please confirm you can login using my username and password? Thank you.
[2014-05-06 20:40:48]
Yes we can.
[2014-05-06 21:05:04]
I have tried completing disabling the firewall, and I am still not able to login. Any thoughts or suggestions you have would be appreciated.
[2014-05-06 21:10:42]
Do you still get this error code?:
Are you able to browse the Sierra Chart website with Microsoft Internet Explorer?
[2014-05-06 21:38:39]
I can browse the site, and can also ping the site, but I still get the above error message.
[2014-05-06 22:52:58]
What firewall are you running?
Would you happen to be running Norton or McAfee.
The standard Windows firewall is not a problem and can be running.
Date Time Of Last Edit: 2014-05-06 22:53:13
[2014-05-07 12:16:04]
I'm running Comodo Internet Security Pro. I can ping and visit the site without problems.
[2014-05-07 17:04:02]
And do you continue to get the same error message?:
If so, then that most likely is the program that is blocking the connection. Our suggestion is to restart the computer into Window Safe Mode with networking support. And see if you can log into Sierra Chart after that.
Date Time Of Last Edit: 2014-05-07 17:04:18
