Date/Time: Sat, 15 Mar 2025 07:40:10 +0000
TPO Not Printing Suddenly
View Count: 428
[2022-07-05 16:24:39] |
User878340 - Posts: 3 |
Hi, My TPO has suddenly stopped printing letters - as you can see I am missing letters... Nothing changed in my setup or settings, it just disappeared. thx |
![]() Attachment Deleted. |
[2022-07-05 16:39:13] |
Check the Session Times of the chart: Chart Session Times: Session Times And make sure they cover the current time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-05 22:35:40] |
Worked great - thanks
