Date/Time: Fri, 14 Mar 2025 22:26:42 +0000
Placing Market Orders using Mouse
View Count: 533
[2022-07-05 15:30:48] |
Steve Leon - Posts: 312 |
I am writing to ask if you would consider allowing for straight market buy and sell orders to be placed using the mouse by clicking above/below current price in buy/sell column as opposed to just using the trade menu. Right now i am using market if touched - client; which is the only option available in the Global settings trade menu. I guess you could use buy stop and sell stop type orders but they wont get you in the market right away if you are trading using a point and click method and you are not close to the price you want enter in on the DOM. I think this would be helpful for entry and exit in the faster/more volatile markets. Thank you for your consideration Thank you Steven |
[2022-07-05 19:10:12] |
John - SC Support - Posts: 38678 |
We have set this as a Feature Request. But, we also want to let you know that you can setup Keyboard Shortcuts for "Buy Market" and "Sell Market". Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-06 14:25:12] |
Thank you. Is there anyway to stay updated on if or when you add such a feature. Thank you again for your consideration |
[2022-07-06 17:55:52] |
If we were to perform a change due to a specific Feature Request in this forum, then we would post in this thread that we made the change. Otherwise, the only other way to see if a particular change is in the software or not is to look at the Version Notes at the following link: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Just keep in mind that we can not say when we will get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
