Date/Time: Fri, 14 Mar 2025 22:26:42 +0000
My charts arent refreshing
View Count: 465
[2022-07-05 15:22:08] |
User183724 - Posts: 193 |
My charts arent refreshing. the only way i can get new bars is using edit / download / reload data manually. I havent updated anything... thx tim
[2022-07-05 15:32:10] |
John - SC Support - Posts: 38678 |
You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-06 06:27:28] |
Let us know if you need further help.
