Date/Time: Fri, 14 Mar 2025 22:29:04 +0000
ChangeFromOpen% does not work in Quote Board for all symbols [Denali Exchange Data Feed]
View Count: 525
[2022-07-05 13:15:09] |
User889191 - Posts: 61 |
ChangeFromOpen% does not work in Quote Board for all symbols. They are not always same symbols. Afert reconnect different symbols have issue of ChangeFromOpen% is 0.00%. Please fix it. thx
[2022-07-05 13:41:30] |
Add the Open price field and bring it into view so we can see it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-05 13:41:34
[2022-07-05 13:45:14] |
Here you go.
[2022-07-05 14:03:40] |
We are not seeing any problem with the Open price ourselves after repeatedly reconnecting. It always displays. So not sure what is the issue in your case. We need to think about this.
[2022-07-05 14:08:40] |
It started a few weeks ago after upgrading(don't know which version). It is not there every day.
[2022-07-05 14:12:26] |
Sometimes it is getting better(fewer Symbols have the issue) after reconnect. As today. 2nd reconnect solved it for a few symbols.
[2022-07-06 09:20:56] |
We implemented a solution to this.
[2022-07-06 09:22:04] |
Excellent. Thx.
