Date/Time: Fri, 14 Mar 2025 22:29:08 +0000
[User Discussion] - Low volume area extended line
View Count: 456
[2022-07-05 05:17:43] |
MFT_ - Posts: 12 |
Hey guys, Is it possible to mark an low / thin volume area, based on an volume threshold, from an footprint bar? And mark it by extended lines. Any push in the right direction is welcome. Best |
[2022-07-05 18:19:26] |
John - SC Support - Posts: 38678 |
There is not an automated way to do this. You would have to use the Horizontal Ray or Extended Rectangle and manually mark the location.
[2022-07-07 09:17:34] |
MFT_ - Posts: 12 |
I don’t know anything about coding, but is this something that can be coded within SC?
[2022-07-07 17:16:39] |
Yes, it can be coded in SC. Refer to the ACSIL documentation starting here: Advanced Custom Study Interface and Language (ACSIL) And the following is a list of programmers that you can contact and see if they can produce what you want: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
