Date/Time: Fri, 14 Mar 2025 22:22:29 +0000
Change the Time Period Length on 9 separate Percent Change Since Open?
View Count: 476
[2022-07-04 21:09:23] |
58LesPaul - Posts: 429 |
I have 9 Sector ETF's on one chart and showing Percent Change Since Open. Is there any way to change the Time Period Length all at once for all 9 studies instead of changing each one separately? I would like to be able to see the percent change for different time periods, say a week, month, 6 months, etc. Or do I have to duplicate the chart for each time period I want to see? Thanks |
[2022-07-05 18:14:16] |
John - SC Support - Posts: 38678 |
There is a link option for Studies that you can use. Just keep in mind that it will make all the charts that share the link use the same studies and settings. If you just have the one study, then this would work well for you. Refer to the following: Chart Settings: Linking Otherwise, there is no good option for how to change multiple charts studies, but you might find the Study Collection to be a faster method than others. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
