Date/Time: Fri, 14 Mar 2025 22:20:04 +0000
Changement de flux
View Count: 397
[2022-07-04 17:02:13] |
User525038 - Posts: 14 |
Bonjour J'ai ajoutĂ© 33 $ sur mon compte pour avoir le flux du SP 500, je n'ai aucun flux! J'ai peut ĂȘtre fait une erreur, merci de rectifier |
[2022-07-05 18:04:02] |
John - SC Support - Posts: 38678 |
From Google Translate: I added $33 to my account to get the SP 500 stream, I don't have any streams! I may have made a mistake, please correct
Everything on your account looks good. Keep in mind that yesterday was the 4th of July Holiday in the US, so perhaps that was the issue you were having. If you are still having a problem, then please let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
