Date/Time: Fri, 14 Mar 2025 22:31:38 +0000
Different Intraday Charts Case on Same Symbol
View Count: 380
[2022-07-04 13:42:15] |
User793920 - Posts: 10 |
Dear Support, I hope my message finds you well. I am facing the following case: I am opening FDAXU22 Future contract and set the chart with 1 trade. When I open same Future contract FDAXU22 on another PC with chart setting 1 trade again, I see big differences between both charts, nevertheless settings are the same. Please find below links for visualization of both charts on the same FDAXU22 Future contracts, which is set with same settings, but have different visualization: https://www.sierrachart.com/image.php?Image=1656941676869.png https://www.sierrachart.com/image.php?Image=1656941805832.png Could you please advise if this is based on issue, or some additional chart settings (I did several time opening same symbol with same settings on both PC, but every time both charts seems completely different. Please advise what is the reason for this issue. Many thanks in advance. With best regards, Miro |
[2022-07-04 13:56:15] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
