Date/Time: Fri, 14 Mar 2025 22:29:05 +0000
trading service connection
View Count: 374
[2022-07-04 12:40:22] |
User410836 - Posts: 18 |
Hi, I am a AMP FUTURES Customer. I am using CQG for Order routing. Due to change in your services; I am also subscribed to Denali exchange Data Feed. Under Data/Trade service settings, I have CQG WEBAPI(TRADING) selected. If I want to use Sierra Charts only for data and charting and not for order routing, which selection I should make....SC DATA---ALL SERVICES? Kindly advice.....Thanks Date Time Of Last Edit: 2022-07-04 13:13:47
[2022-07-04 13:34:22] |
For what you want to do refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees The answer to your question is yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-04 13:34:37
