Date/Time: Fri, 14 Mar 2025 22:31:36 +0000
Custom Calculated Symbol category name has disappeared
View Count: 431
[2022-07-04 00:50:02]
SierraFan - Posts: 92
Version 2411. I have custom symbols that were created by using the directions in "custom calculated symbol" ex.{ESU22_FUT_CME}/{ZBU22_FUT_CME}. I've been using these for well over a year(of course when roll over happens I have create new spreads and now the category I created for all the symbols is gone. The category name created is no longer showing up in the find symbol menu. These custom symbols/spread aren't visible. Has something changed? Custom Calculated Symbols
[2022-07-04 01:07:58]
Heres an example from version 2400. U can see custom category is still showing up.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=66354
imageScreenshot_2.jpg / V - Attached On 2022-07-04 01:07:20 UTC - Size: 403.92 KB - 135 views
[2022-07-04 09:54:55]
We observe no issue with this on the latest version.
Make sure that in Global Symbol Settings the option to Use Custom Symbol Settings Values is enabled:
Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings)
[2022-07-04 17:03:24]
That was it! I just checked the box and everything came back. Apologize for the inconvenience Sierra. Thank You!!!!
