Date/Time: Wed, 19 Mar 2025 19:44:04 +0000
Am I an idiot or can you not hide the last trade price arrow on TPO charts?
View Count: 675
[2022-07-03 02:41:31] |
User1293821 - Posts: 42 |
Subject says it all. If you can't I feel it would be very easy to add functionality...the reason being is I overlay settlement from Daily Charts. Thanks SC Team.
[2022-07-03 12:06:53] |
No, this is not supported. But we could add this functionality.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-03 12:07:06
[2022-10-31 18:58:55] |
BillyVLLR - Posts: 16 |
In the meantime, I suggest that you use the same chart background color for the Last Price Arrow, this solves the issue.
