Date/Time: Fri, 27 Sep 2024 00:34:45 +0000
[User Discussion] - Flex Renko Reversal Bar
View Count: 466
[2022-07-02 02:07:39] |
User469312 - Posts: 96 |
Hello, looking for help using Flex Renko Bars. This example is just generic & not security specific. I am using the reversal bar as the trigger then + 3 bars in that trend from the reversal bar. So if the Reversal bar is a Sell, then + 3 bars after that print and if in the same trend a trade will fire until other criteria is set or another reversal bar and 3 bars follow. I have attached a chart. On the chart I have circled the reversal bars and placed a blue square where a trade would fire (Buy or Sell). Any insight or guidance would be appreciated. https://www.sierrachart.com/image.php?Image=1656727507341.png |
