Date/Time: Sat, 20 Apr 2024 07:28:44 +0000
Study Price Overlay Question
View Count: 1611
[2013-04-27 04:29:45] |
User22396 - Posts: 191 |
I am tryin to plot a study from a Daily chart to a Intraday chart but the plot is not synch'd ...it changes mid day at 12:00 instead of the globex evening start is there a way to have the plots in synch at globex evening start? thanks b |
[2013-04-28 00:34:58] |
We will add this capability to the next release. The will require that you properly set the Session Times in Chart Settings in the destination Intraday chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-28 00:35:38
