Date/Time: Fri, 14 Mar 2025 18:03:01 +0000
Hi
View Count: 409
[2022-07-01 18:26:42] |
User437787 - Posts: 1 |
Hi, I’m a currency trader (forex) I will like to know if you have currencies chart eg. EURUSD, GBPUSD ets.. and if I can use the Numbers Bar (footprint/Delta ) on them
[2022-07-01 18:36:01] |
John - SC Support - Posts: 38669 |
We have data from FXCM for FOREX. You will find the list of what is available when you select File >> Find Symbol and then select the section for Forex - FXCM in that list. The FOREX data is provided at no additional cost. You can use the Numbers Bars study with the FOREX data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
