Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
CQG Connection
View Count: 388
[2022-06-30 22:48:41] |
User787305 - Posts: 14 |
I cannot connect this evening to CQG. I have servioce pkg 10 with Denali. I submitted the message log. Thank you and I look forward to your response. Mike Allen |
[2022-07-01 04:55:47] |
There is no connection attempt to CQG but instead Gain capital: GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2022-06-30 17:33:59.436
Follow through the CQG instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
