Date/Time: Fri, 14 Mar 2025 17:52:51 +0000
Settings menu dark background with grey text hard to see.
View Count: 579
[2022-06-30 21:39:47]
Mike_S - Posts: 42
The settings menu, or all menu's now have a dark background with grey text that is hard to see.
How do I bring back the old format with the light background and dark text?
It' like i'm looking at an old DOS computer now.
imageDark.png / V - Attached On 2022-06-30 21:39:10 UTC - Size: 52.52 KB - 140 views
[2022-06-30 21:43:58]
John - SC Support - Posts: 38669
You can not bring back the old format, but you can change the colors of these windows along with a number of other options. Refer to the following:
Settings Windows Interface: Colors and Font Settings
[2022-07-01 02:41:24]
58LesPaul - Posts: 429
Here's mine. Reminds me of the old one so I am somewhat at ease.
imageSierra Chart 2408 ES 60-15-5 SC Data - All Services 2022-06.png / V - Attached On 2022-07-01 02:41:16 UTC - Size: 26 KB - 161 views
[2022-07-01 08:09:17]
Yes the colors are fully configurable. Even the button colors and the Yes/No text items. There are a total of 11 color settings.
[2022-07-01 13:28:31]
Mike_S - Posts: 42
Thank you. You guys should consider changing the default settings for that. It was literally giving me anxiety to look at.
It makes it look cheap. But that's just one opinion I'm throwing in there though.
Then again, you never finds any websites or anything that really compares to those settings so that might say something.
Thank you for the help.
Date Time Of Last Edit: 2022-07-01 13:43:06
