Date/Time: Fri, 14 Mar 2025 19:11:08 +0000
graphic settings
View Count: 453
[2022-06-30 20:39:50]
User203192 - Posts: 33
Is there a way to change the over all appearance of the lines on the page. I have gotten a new computer, same brand some softwear, better graphics but the lines look worse on the new computer. Tried changing all my setting on the computer aspects and nothing will work. Not sure if the upload works but the older computer lines look a lot more crips. Tried interactive scale, adjusting chart sizing with the number in lower right corner, text size. The lines just look a little more cartoon like and I'm use seeing the lines a certain way when I trade and the change is a little difficult to adjust to, as some of the nuances in the line appearance is the difference between win and lose?
Private File
imageScreen Shot 2022-06-30 at 4.02.36 PM.png / V - Attached On 2022-06-30 20:35:11 UTC - Size: 685.94 KB - 133 views
[2022-06-30 21:36:51]
John - SC Support - Posts: 38669
It looks like you are not running your computer at the highest graphics size possible. Check your operating system graphics settings first.
