Date/Time: Fri, 14 Mar 2025 17:52:53 +0000
[Programming Help] - ACSIL: Flatten all positions
View Count: 466
[2022-06-30 20:06:26] |
ycomp - Posts: 321 |
How do you flatten all positions using code? I could loop all positions and check which are open using GetPositionByIndex() The part I got stuck at is how do you set the current position? All the flatten methods seem to work only on the current position. |
