Date/Time: Fri, 14 Mar 2025 18:03:01 +0000
Quoteboard not linking with duplicated shared DOM
View Count: 482
[2022-06-30 18:08:59]
Thaddeus Fulmer - Posts: 71
1. After duplicating a shared DOM to a chartbook, the DOM symbol does not change from pressing the Quoteboard symbol. All the other charts change but not the duplicated DOM. The linking literature doesn't seem to apply here.
2. Is there a way to save the shared DOM as a template or default? I want the exact graphic settings.
Thank you,
Thaddeus
imageScreen Shot 6-30-2022 at 1.56 PM.png / V - Attached On 2022-06-30 18:07:29 UTC - Size: 331.47 KB - 115 views
imageScreen Shot 6-30-2022 at 1.59 PM - 2.png / V - Attached On 2022-06-30 18:07:36 UTC - Size: 213.61 KB - 119 views
[2022-06-30 19:28:28]
John - SC Support - Posts: 38669
1. The link options stay with the Trade DOM when it is duplicated. Are you using a different Link Number in the other chartbook than what that Trade DOM Was originally setup for? Check the Link options of the charts and the Trade DOM and ensure they are using the same Link Number and that the Symbol option is enabled for the Trade DOM.
Refer to the following for information on Linking:
Chart Settings: Linking
2. Refer to the following:
Using Chart Templates
Date Time Of Last Edit: 2022-06-30 19:29:17
