Date/Time: Fri, 14 Mar 2025 19:01:28 +0000
Trading Question
View Count: 390
[2022-06-30 17:29:56] |
Andrew Pringle - Posts: 4 |
Hi, The BUY ORDER COLUMN and the SELL ORDER COLUMN on the DOM are still blank, there is no data? Basically I do not appear to be seeing the 10 levels of LIMIT ORDER's on the BID and ASK side.
[2022-06-30 19:22:46] |
John - SC Support - Posts: 38669 |
Refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
