Date/Time: Tue, 26 Nov 2024 11:57:17 +0000
Time Count Tool
View Count: 1470
[2014-05-06 00:28:54]
BruceWilson - Posts: 15
Is it possible for you to develop a time count tool please?
It would be good in the case of daily charts to be able to take a high/low, apply the tool and get a count from the starting date marked off on the chart of the programmable numbers e.g. 21, 34, 55 days etc.
Can it be done in calendar days and trading days and also on any other time frame?
Here is how DT handles it at https://www.youtube.com/v/mk2ctDkO2cQ
Thank you and best wishes
Bruce
[2014-05-07 09:00:19]
The closest Sierra Chart has to this is the Time Expansion and Time Projection drawing tools:
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#TimeExpansion
There are no plans to add anything new.
You can also just draw Vertical lines yourself at future dates in the chart.
And you can control how many future dates will be included in a Historical Daily chart with the Chart >> Chart Settings >> Advanced Settings >>Number of Forward Columns setting.
Date Time Of Last Edit: 2014-05-07 09:01:03
[2014-05-07 21:53:24]
Thanks anyway. I've found a way to hack the Time Expansion tool to give me what I want.
Cheers Bruce
