Date/Time: Fri, 14 Mar 2025 19:06:44 +0000
DOM slower if adding Recent Vol columns
View Count: 462
[2022-06-30 17:25:58] |
User293778 - Posts: 21 |
Hi SC team, Is it possible that the trading DOM can suffer a slight performance hit when adding the Current and Recent Traded Volume columns? I have noticed that on the Bund: if I use only the Cumulative LTQ column plus bid&ask sizes the DOM performs super-smooth but if I add the other columns the DOM seems to become jumpier. I have a 10ms refresh rate only for the DOM. Thanks. |
[2022-07-01 10:05:42] |
Sierra_Chart Engineering - Posts: 18784 |
Certainly there is more processing but it should be very minimal. Most of the processing would be due to the graphics output. It could be that you need to clear the current traded volume by using this command, to increase the speed: Trade Menu: Clear Current Traded Bid/Ask Volume (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-01 10:07:15
