Date/Time: Sat, 26 Sep 2026 16:00:42 +0000
Denali not streaming
View Count: 728
[2022-06-30 15:31:35]
User673674 - Posts: 4
Denali not streaming- not getting current data. I'm paid up and i think all connections are good? Please advise.
Software version: 2403 64-bit | 2022-06-30 10:30:17.321
Primary Thread ID: 10452 | 2022-06-30 10:30:17.321
Usage end date: 2022-07-10 | 2022-06-30 10:30:17.321
Enabled for: Sierra Chart Historical Data Service. | 2022-06-30 10:30:17.321
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-06-30 10:30:17.321
Enabled for: Delayed Denali Exchange Data Feed. | 2022-06-30 10:30:17.321
Enabled for exchange2: CME (Trading Account Required) | 2022-06-30 10:30:17.321
Enabled for exchange2: CBOT (Trading Account Required) | 2022-06-30 10:30:17.321
Enabled for exchange2: COMEX (Trading Account Required) | 2022-06-30 10:30:17.321
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-06-30 10:30:17.321
Enabled for exchange2: fairx_exchange.data | 2022-06-30 10:30:17.321
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-06-30 10:30:17.321
Current selected Data/Trading service: Teton CME Order Routing | 2022-06-30 10:30:17.321
Custom symbol settings values: enabled | 2022-06-30 10:30:17.321
Chart Update Interval: 500 | 2022-06-30 10:30:17.321
Intraday Data Storage Time Unit: 0 | 2022-06-30 10:30:17.321
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-06-30 10:30:17.321
2022-06-30 15:30:17 Local computer time in UTC | 2022-06-30 10:30:17.321
2022-06-30 10:30:17 Local computer time in SC Time Zone | 2022-06-30 10:30:17.321
Program path: C:\SierraChart\ | 2022-06-30 10:30:17.321
Data Files path: C:\SierraChart\Data\ | 2022-06-30 10:30:17.321
OS Version Number: 10.0 | 2022-06-30 10:30:17.322
Locale Setting: C | 2022-06-30 10:30:17.322
DLLs: TriStar_FuseLines_v2_64.dll, TriStar_Multi_VBS_BckGrnd_v1_64.dll, TriStar_Renko_DojiBar_v1_64.dll, TriStar_Renko_Doji_SigSys_v1_64.dll, TriStar_Renko_SyncBar_v1_64.dll, TriStar_Renko_XPOC_v1_64.dll, TriStar_STRATbars_v2_64.dll, TriStar_STRATcombos_v4_64.dll, UserContributedStudies_64.dll | 2022-06-30 10:30:17.322
Allowed protected custom studies: | 2022-06-30 10:30:17.322
Crash reporter started: true | 2022-06-30 10:30:17.322
Teton CME Order Routing | Firm: Dorman | 2022-06-30 10:30:30.602
Teton CME Order Routing | Connecting to the server futurestrading1.sierracharts.com. Port 11090 | 2022-06-30 10:30:30.602
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-06-30 10:30:30.602
DTC Client socket (1) | c_EncryptionIOBuffers memory error. | 2022-06-30 10:30:30.602
DTC Client socket (1) | CloseSocket call. | 2022-06-30 10:30:30.603
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-06-30 10:30:30.603
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-06-30 10:30:30.603
DTC Client socket (0) | CloseSocket call. | 2022-06-30 10:30:30.632
Teton CME Order Routing | Disconnected. | 2022-06-30 10:30:30.632
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-06-30 10:30:30.632
Saved Chartbook: Chartbook2.Cht. Time: 0.0401 seconds. | 2022-06-30 10:30:41.384
[2022-06-30 15:50:37]
First time we have seen someone get this error:
Could you restart Sierra Chart. And after that restart your computer if necessary.
And also run Sierra Chart in safe mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
Date Time Of Last Edit: 2022-06-30 15:51:20
[2022-06-30 16:18:42]
ok - I restarted my computer and then I'm getting live data,
[2022-06-30 18:18:54]
TriStar Trading - Posts: 200
Is that something you might think is PC related?
