Date/Time: Fri, 14 Mar 2025 17:57:59 +0000
bougies
View Count: 404
[2022-06-30 15:05:26]
User220939 - Posts: 36
Bonjour,
Je voudrais avoir des bougies trimestrielles mais je ne trouve pas.
est ce possible de les avoir ou il faut rester en quadrimestre?
Merci
[2022-06-30 18:12:35]
John - SC Support - Posts: 38669
From Google Translate:
I would like to have quarterly candles but I can't find it.
is it possible to have them or do you have to stay in a quadrimester?
Quarterly is an available option for historical data. First, you need to set the Chart >> Chart Settings >> Bar Period >> Chart Data Type to Historical Data and then you can select Quarterly for the Chart >> Chart Settings >> Bar Period >> Historical Chart Bar Period Type.
Refer to the following:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu)
