Date/Time: Fri, 14 Mar 2025 19:11:07 +0000
Alert vs Ascil performance
View Count: 530
[2022-06-29 21:16:00] |
BenjFlame - Posts: 335 |
Hi is there any performance disadvantage of using alert system for detecting conditions and coloring vs doing the same with pure ascil?
[2022-06-30 07:04:58] |
You mean using the Color Bar Based on Alert Condition study? Using ACSIL would be faster. Although not necessarily. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
