Date/Time: Fri, 14 Mar 2025 19:06:44 +0000
Orders/Positions on Chart DOM - graphics
View Count: 992
[2022-06-29 20:14:05] |
Steve Leon - Posts: 312 |
I am looking to change the chart orders and positions graphics colors. Right now the default - the position/price/profit and loss info to the far left of the chart and i wanted to move the tab to the right side possibly eliminationg the line I tried to find it in the documentation but could not Thank you |
[2022-06-30 16:57:00] |
John - SC Support - Posts: 38669 |
First refer to the following to define what you want the coloring to be defined by: Global Trade Settings Windows: Coloring Of Position Line Based On (Global Settings >> Chart Trade Settings >> General >> Chart Position Line) Then refer to the coloring options starting here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Position Line Long/Profit And refer to following setting to align the order lines to any position within the chart: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeDrawingsLeftAlignPercent For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-30 18:18:16] |
Thank you very much. I was able to clarify my question I had a second related question. Is there a way to display the Trade/Order and Position Lines in the DOM part of the chart (on the Chart DOM) like on the Trade DOM. For example in one of the General Purpose Columns; so that the orders and positions can be handled like on the Trade DOM ? |
[2022-06-30 19:55:51] |
Is there a way to display the Trade/Order and Position Lines in the DOM part of the chart (on the Chart DOM) like on the Trade DOM. This part of your statement has us confused. On the Trade DOM, the Order and Position Lines are not in the DOM itself, they are just pushed up next to it. You can do this using the Trade Drawings Left Align % option as noted above. Here is the link again: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeDrawingsLeftAlignPercent The only difference that we can think of is the display of the prices in the Price Ladder on the Trade DOM, which is not done on the Chart DOM. There is not a way to change this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-30 20:09:29] |
Sorry about the lack of clarity on my part. I think you gave me the answer. Which is it cant be done I am attaching a picture of my Trade DOM showing the order lines if this is what you call them I wanted to see if they could be right near the price ladder. which would put them as part of the DOM and not the chart. So to the right of the chart |
Attachment Deleted. ![]() |
[2022-06-30 21:33:07] |
There is no support for what you are wanting with the order lines.
