Date/Time: Fri, 14 Mar 2025 19:11:07 +0000
Chart DOM graphics
View Count: 511
[2022-06-29 19:15:39] |
Steve Leon - Posts: 312 |
Are you able to change the background on the Chart DOM to a different color than the background on the chart itself using for example Chart DOM Bid/Ask Background like you can change on the Trade DOM ? When I try either through global settings or chart settings nothing happens Thank you |
[2022-06-30 16:37:15] |
John - SC Support - Posts: 38669 |
Most of the graphics settings that exist for the Trade DOM also exist for the Chart DOM. In the Global Settings >> Graphics Settings - Global you will find both sets of entries (Chart DOM and Trade DOM). Most of the columns have the ability to have their background changed (it may be all, but we would have to double-check the Label and General Purpose columns). The only one that does not (for sure) is the Price Ladder itself. That is always using the color of the main chart background (in the case of the Chart DOM). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
