Date/Time: Fri, 14 Mar 2025 19:11:07 +0000
Negative On my Balance/ Trade Error
View Count: 564
[2022-06-29 18:50:14] |
User219716 - Posts: 1 |
Hi I am having some issues with my my P&L it's currently showing a negative of 729 points, also when I place any limit order it's always putting my order in at market , I would be happy if someone can reach out to me via telephone so I can rectify these issues.
[2022-06-30 11:34:47] |
also when I place any limit order it's always putting my order in at market Regarding this we need to know what the order type is. Check the Trade >> Trade Orders Window and find out what the order type is. Confirm it is actually a Limit order. For issues with the Daily Profit/Loss value, refer to: Help With Daily Profit/Loss Value we also see you are running an older version of Sierra Chart you should update: Software Download: Fast Update However, be aware of this information regarding CQG Market data: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-30 11:34:48] |
also when I place any limit order it's always putting my order in at market Regarding this we need to know what the order type is. Check the Trade >> Trade Orders Window and find out what the order type is. Confirm it is actually a Limit order. For issues with the Daily Profit/Loss value, refer to: Help With Daily Profit/Loss Value We also see you are running an older version of Sierra Chart. You should update: Software Download: Fast Update However, be aware of this information regarding CQG Market data: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-30 11:35:12
